GLK24064-25-IU Not Detecting COM Port after wipe
Dilipkumar
Post by Dilipkumar »
Hi All,
i used GLK24064-25-IU this with MOGD#1.1.8 after used wipe command i am not able use this device .Device was not detect & Error :Connot open comport
Regards,
Dilip
Re: GLK24064-25-IU Not Detecting COM Port after wipe
Hi Dilip,
Welcome to the forums!
I understand that you have a GLK24064-25-1U display, and after using MOGD to wipe the display, you are not able to detect the display again.
Could you tell me what PCB Revision you have?
Also, did any errors occur while you were wiping the display?
Dan
Dilipkumar
Hi Dan,
Thank you for reply.There no errors on wipe process & PCB revision Board 1.0.
Hi Dilip,
Are you using a USB GLK24064R-25-1U display variant? Also, have you installed the proper USB drivers on the display?
