EVE2-70A TPR display with diagram blinks and goes blank
madhusudan.jadhav
Post by madhusudan.jadhav »
Hi there,
I have EVE2-70A TPR display interfacing with xmc4500 . I write don the code which is attached. the display with backlight blinks and again goes blank after start. please help.
main.c
(40.57 KiB) Downloaded 399 times
API.c
(64.93 KiB) Downloaded 397 times
Re: EVE2-70A TPR display with diagram blinks and goes blank
If you please check out this sample demo code we have for the EVE's:
https://github.com/MatrixOrbital/Basic-EVE-Demo
You may check out the code and use it as reference.
madhusudan.jadhav
Ok Thank you ,
I put API_END before API_DISPLAY
