Problem with EVE2-50G-BLM-TPC and EVE2-USB2SPI-KIT-A
eframefactory
Post by eframefactory »
I am using the EVE2 50G display in combination with the EVE2-USB2SPI-KIT-A on my Windows PC.
The problem is as follows.
The display shows horizontal waves that move from the bottom to the top.
I then replaced the EVE2-USB2SPI-KIT-A with a new one.
The problem was solved.
Now, 6 months later, the same problem.
I power the EVE2-USB2SPI-KIT-A with a Samsung charger with 5V voltage.
What could be the problem?
Greetings Eddi
horizontal waves that move from bottom to top
Re: Problem with EVE2-50G-BLM-TPC and EVE2-USB2SPI-KIT-A
Hello Eddi,
Are you able to test out the power coming from the USB2SPI bridge?
Can you please check it using a scope?
Can you also try supplying external power via the barrel jack? Center positive, 5V-12V 1A if you have it.
