Basic Arduino EVE Demo
Basic EVE Arduino UNO Example Code
Written for an EVE2 or EVE3 or EVE4 running on an Arduino UNO.
Code is located on GitHub
https://github.com/MatrixOrbital/EVE-Basic-Demo-Arduino
This code when executed will display MATRIX ORBITAL text and a circle switching between blue and red.
This code will illustrate:
  • EVE initilization
  • Set colour
  • Draw circle
  • Write text
please note, this example does not utilize touch
Hardware Requirements
Designed for Matrix Orbital EVE2/3/4 SPI TFT Displays
https://www.matrixorbital.com/ftdi-eve
Scoodo EVE TFT SHIELD for Arduino
https://www.matrixorbital.com/eve2-shield
LIBRARY
This code makes use of the Matrix Orbital EVE2 Library found here:
https://github.com/MatrixOrbital/EVE2-Library
While a copy of the library files (Eve2_81x.c and Eve2_81x.h) is included here, it will not be updated. For the most up to date files please use the files from the link above.
EVE SPI TFT connected to a Scoodo SHIELD
Support Forums
http://www.lcdforums.com/forums/viewforum.php?f=45
prestonpressure
Re: Basic Arduino EVE Demo
Post by prestonpressure »
The library found here: https://github.com/MatrixOrbital/EVE2-Library does not provide for a very basic function of changing the line width. The functions listed below are located in the Eve2_81x.h file, but there is no way that I can find to change the line width. There is a LINE_WIDTH command in Section 4.32 of the Programmers Guide, but I do not find this in the library. Is there another way to change the width of a line?
// Primitive Type Reference Definitions - FT81x Series Programmers Guide Section 4.5 - Table 6
#define BITMAPS 1
#define POINTS 2
#define LINES 3
#define LINE_STRIP 4
#define EDGE_STRIP_R 5
#define EDGE_STRIP_L 6
#define EDGE_STRIP_A 7
#define EDGE_STRIP_B 8
#define RECTS 9
you can find the definition for line width over here
https://github.com/MatrixOrbital/EVE2-L ... 81x.h#L365
prestonpressure
Thank you! Apparently I had an older version of this library.
