I have a nine slice image and file setup but when I tried removing the HSCALE keyword from the file it doesn't have any effect. The top middle portion always stretches instead of repeating when displayed using the display nine-slice command FE 91.
I also tried experimenting with different TRANS-R, TRANS-G, and TRANS-B value but did not see any difference.
Is there a particular scenario in which these apply?
Nine slice VSCALE/HSCALE
Re: Nine slice VSCALE/HSCALE
Hello dr21702,
If you please email your 9-slice file and the bitmap and I will check here.
support@matrixorbital.ca
-Raquel
-Raquel
Test files are attached. From the documentation, leaving out HSCALE should make the top center with orange boxes tile instead of stretching and white should be transparent.
- TestNineSlice1.txt
- (105 Bytes) Downloaded 274 times
- TestNineSlice1.png (1.34 KiB) Viewed 10317 times
Hello dr21702,
What you are observing is correct.
There is no implementation of tiling for the 9slices currently.
I will see what I can do to request to have this implemented.
