Internal Mounting
A Gallery of pictures...
Here are going to be pictures of internal mounting of Displays...
Rules:
1. No asking how it was done in this thread, take it to general, or hardware or PM.
2. Please keep the pictures less then 500 pixels (width) in size.
3. Give some information on how it was done.
4. If you need web hosting, please e-mail me and I'll host your pictures.
5. Dead links will be deleted.
6. If you have a homepage with more pictures or details, please give it at the bottom.
Format:
Unit: BLK202A-4BR
Software: LCDC
Case: Standard Mid Tower
Difficulty: Easy
Other: I added LEDs to the bottom using the GPOs.
PIC 1
PIC 2
Materials Needed: (list where and so on to help other modders )
ETC...
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-07-10 10:06 ]</font>
<font size=-1>[ This Message was edited by: Henry on 2002-09-12 10:23 ]</font>
OK, I'll go first here :grin:
Unit: BLK202A-4BR
Case: Standard Mid Tower (I know, I know)
Difficulty: Easy :smile:
Other: Used blue LEDs and connected them to the GPOs to show when I get new mail...
LEDs are from Digikey P467-ND.
_________________
linear
evil Dr. linear
evil Dr. linear
Post by linear »
Me second:
Unit: LK204-25
Case: Custom acrylic cube
Difficulty: difficult
Other: The unit is mounted in the drive cage behind acrylic. Motherboard standoffs are threaded into the acrylic sheet, and M3 screws attach the unit from the rear. The standoffs were modified by grinding them down so they didn't extend through the thickness of the .125" acrylic sheet. The PSU for the system is behind the LCD. Serial port is wired to the pin header for COM2 on the motherboard with an IDC female connector.
Materials Needed: motherboard standoffs available at PC retail outlets everywhere and M3 screws from hardware store. 6-32 tap used for threading mounting holes.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Unit : BLK202A-GW-BK
Case : CM201
Hardnessie factor : -1/10
Other comments : I would have made more effort and used the lcd to it full by adding led's etc. but it's not staying long
Beaucoup
Post by Beaucoup »
Unit: LK162-12
Case: Microsoft Internet Keyboard Pro
Difficulty: Medium
Other: It's a tight fit, and to make room inside the keyboard, I had to remove a screw column, reposition a few capacitors on the keyboard's controller, and file down the chassis for those three Internet buttons a bit. To scale down the display itself, I removed all of it's headers and connectors, and seperated the serial backpack from the main display, reconnecting it near the center of the keyboard with some ribbon cable. I also dremelled off the display PCB's top-right corner, and took two or three millimeters off the top edge(It's THAT tight a fit). Everything is powered off the keyboard's built-in USB hub via a stripped down USB-to-Serial adapter cable embedded inside.
Hey, I finally got around to taking an internal picture. From left to right, you see the USB/Serial adapter, the LCD's Serial backback, and the keyboard's own controller.
Materials Needed: Phillips screwdriver, Dremel tool with drilling/cutting bits, file, soldering iron, hot glue gun, USB-to-Serial adapter(PL2303 chipset based), wire & drive ribbon cable.
{Hosted Pictures}Henry
Stig
Post by Stig »
Unit: LK204-25PC
Case: Chieftec Dragon Big Tower
Difficulty: Medium
Other: Connected blacklight cc, blue cc, keypad lighting and casebadge lighting to GPOs.
I separated the pcbs and mounted the controller card on the Digital Doc 5 and the display card in the front door of the case.
Materials needed: Dremel with various accessories, epoxy glue, screws, stand-offs, pcb-making equipment (for the keypad), other bits and pieces.
There will be an article about this mod on http://www.oestvang.no when I get my thumb out of my ****, but in the meantime there are a lot of pictures on here with quite descriptive names about the pictures.
Stig
CriticalPoint
Post by CriticalPoint »
LCD on Project Crucial:
Case: Modified mid-tower, unknown brand
Difficulty: easy-medium
Other notes: Fairly easy, drilled the hole with drill, used scroll saw to cut out a square then filed it down to exact. The LCD doesn't work, it is broken right now, but that will change. I plugged in power wrong.
GrAssHoppA
Post by GrAssHoppA »
Unit: BLC2041
Case: Antec SX1040b
Difficutly: Easy
Other: Damn nice LCD if i do say so myself
for the whole view of the case and future upcoming projects go to
http://members.cox.net/traysurfer/index3.htm
_________________
_-NEW SQL QUERY-_
>select * from USER where clue > 0
>0 rows returned
_-NEW SQL QUERY-_
>0 rows returned
ikonis
LCDC Programmer
Post by ikonis »
Unit: LK204-25PC
Case: Enlight 7237
Difficulty: Easy
I am definitly not the master at measuring things...
nor the painting and not scratching of things...
looking at that first pic makes me want to repaint the whole case...
anyways what i did... was take 2 drive blanking things (my last two... hope i dont screw up)
cut.. glue in plexi and mount....
i dont really like it... but im not gonna worry about it until i get a new case
{hosting images on our site}
MeGrog2
Post by MeGrog2 »
Unit: BVK202A-4BR
Case: Generic mid tower
Difficulty: Medium (I had to relocate my cathode switch to my case door which meant drilling, then the plug on the cathode broke so I had to solder on the wires to the switch, and now my power supply fan makes a loud grinding noise for some unknown reason:) )
Other: I like the display alot but I just wish I could get it and the software to act right so I can get it to display what I want it to. Well here are the pics
List of tools: screwdriver(flat and philips)
Detritus
Post by Detritus »
bUnit: VK202-25
Case: Coolermaster ATC 210
Difficulty: Moderate
Here's my latest project. The VFD is mounted via 4 bolts glued to the back of the faceplate.
Currently this is aircooled...next stop watercooling.
l8r,
Detritus
{hosting pics}
graeme
Post by graeme »
Hey all
This is our music PC in the shop , currently hooked up to 7 demo speaker systems through a switch box. To finish the job off , we fitted a BVF-2041 - not really anything original there, but the full pc system certainly grabs some attention. The colour scheme is loosely modelled on those classic jukeboxes with the coloured tubes around them !
Thanks !
_________________
Graeme Clark, Kustom PC's
http://www.kustom.co.uk
Malt_Vinegar
Post by Malt_Vinegar »
Unit: GLK12232-25-SM
Case: Cool Master 210
GLK12232-25-SM in a CM210 azure Drive facia :smile:
:smile:
slippy
Post by slippy »
Unit: LCD2041-WB-V + B2041
Case: Inwin midtower
Diffculty: Hardware (easy); software: Not so easy
Other: more pics will come soon, website will be updated
tarou
Post by tarou »
Case: Shuttle SS51G
Difficulty: Medium
Since it is taller then 3.5 bay, need some case modification.
CD Drive's bottom plate must be removed or cut.
Toggle power switch is installed using original bolt hole. May be I will change them to two momentary switchs that work as keypads!
