Hi, um i wondered if you could answer a few questions i have, ive tried the manual and the forums etc but i cant seem to find exactly what i have to do.
Im trying to use a GPO on my MX412 (LK-204-24-USB) to control a 12v 120mm Case fan. The fan is currently powered by a 4 pin standard molex.
Am i right in thinking i have to use GPO 4/5/6, connect a floppy power cable and unsolder jumper 2 on the PCB? And then do i need the fan to have a 3 pin molex instead.. can i rewire this?
Any help would be much appreciated
oh, the fan is the YS-Tech FD1238
412 + 12v Fan
Welcome to the forums...
The cable you need is a 4 pin to 3 pin converter, we sell them here
http://www.matrixorbital.com/product_in ... an-cooling
you can make your own as well, take a 3 pin cable, cut the end off and a 4 pin cable. solder them together, making sure you use heat shrink so you don't short out the cables.
Hope this helps...
Hope this helps...
