Hi, before sorry for my poor english :(
I try to make i2c communication between "cypress (cy8c29466) on psoceval1 cy3210" and LK204-25.
this is my code :
[i]include "m8c.inc" // include m8c specific declarations
include "psocapi.inc" // include User Module API specific declarations
export _main:
_main:
call I2CHW_1_Start
Call I2CHW_1_EnableInt
M8C_EnableGInt
Call I2CHW_1_EnableMstr
mov A,$50 ; Load slave address (7-bits)
mov X,I2CHW_1_WRITE ; Prepare for a write sequence (8th bit)
call I2CHW_1_fSendStart ; start condition, load previous slave adr and ack[/i]
i have put the pull up resistance (2kOhms)
no jumper on the LK for 50h adr
i put a scope on sda and scl signal:
i can see the start condition, the 7 bits adr, the 8TH R/W bit, but the 9th bit (ack) was at NACK status :(
could you explain to me why the LK dont ACK?
i have try RS232 befor I2C and all was fine.... no problem.
thx for your respond.[/img]
Edit: i have found my mistake........
50h its the 7 bit adr and 8th bit in the same byte
in my code, the adr of the LK become 2Eh in this case :lol:
Probleme with LK204-25 I2C and cypress
Hi sberthelot,
Yes, it is a common mistake that 50h default address of Matrix Orbital modules is taken as 7 bit address, when in fact, this is already the full 8 bit address.
When addressing the module, (default) 50h is the write address and (default) 51h is the read address (the last bit is 0/1 corresponding the write/read bit).
